RCU Forums - View Single Post - prince-america arfs
Old 02-07-2002 | 11:35 PM
Eagle Flyer
My Feedback: (84)
Default Tucano 61
I have the Tucano 61. Went with a TT 91 4 stroker. It comes all setup for 60 size 2 stroke, even includes the needed pitts style muffler to match up to the muffler exit hole that's already in the cowl. The TT 91 muffler lined right up with it. Only had to open it up a little. It also comes with the engine mount installed for a 60 size 2 stroke also. I would have used a Dave Brown 90 size 4 stroke mount cause it has the same bolt pattern as the supplied unit,this fact alone gives you a lot of room to work with for engine choices, except I had a 120 mount on hand so I used it instead. Just had to relocate the top 2 holes, it was easily done. Supplied throttle linkeage lined right up. Servo tray is installed. Rudder is pull/pull, and all needed hardware is included. It assembled easily,quickly and with no "unwanted surprises". Mine is the fixed gear unit. Flies great. If I figure out the picture thing here I'll get it posted for you to get a look at. I've seen the Starship and it is a good looing unit also. I think you'ld be happy with either one. Any thing else you want to know just let me know. Here's my email address if you need anything.
[email protected]
