RCU Forums - View Single Post - failure to maiden
Old 05-31-2006 | 05:44 PM
jollyrogr
Default RE: failure to maiden
thanks for the tip guys. I'll file a flat spot on the nose wheel wire so it can't turn in the steering arm anymore. I also moved the control rod to the outermost hole on the steering arm, so the wheel shouldnt move as much.
I know there's a bunch of you out there with LT40's. How did they balance? Where did you place your rx and battery? I've got an OS 46ax on mine.
