RCU Forums - View Single Post - how to mount a mini board camera
Old 06-01-2006 | 09:05 AM
pshimm
Default RE: how to mount a mini board camera
Wow--this is EXACTLY what I was looking for. Thanks for your response. A couple of questions--Do you think just a couple of rubber bands is secure enough? I see in the pic you have the camera mounted uder the left wing. Have you tried other locations? You used the servo to rotate the camera up and down. Did you consider side to side and why did you choose what you did? The transmitter is located inside the cockpit with the antenna out one side. Does this affect reception when the antenna is facing away from you? Did you consider mounting the transmitter similar to the camera on top of the wing? Maybe in a single unit with the camera and battery? I'd love some more pics of your plane set up and some sample videos.
Thanks again.
-Peter
