RE: BRIO Electric 10-size
Greetings,
Mine liked a 11x7 though, it's kinda' moot now. I was in the bottom of a split S when it stalled/snapped right into the ground. I had the CG on the 100mm mark and the elevator throw was less than the low rate suggestions. There was an old school pattern guy at the field and he saw it go in and we both agreed it was a tail heavy condition with to much elevator throw. You may want to consider moving your CG forward and keeping the elevator throw to less than 1/2". This is not a 3D plane, it's a pattern plane and it should be flown as such.
On a side note - The damage was not to severe and I'm in the process of making repairs. However, the electric is comming off and being replaced with an OS 25fx. I'll let you know how it goes.
Best Regards,
The Dude
