Next time I do a .jpg from ACAD, I'll know to change to white screen black lines before exporting.
After I saw the posts about "Sheetface" I couldn't leave it alone.. I had to do one too.
On the Blink I plan to go fast, but will be using the VA .049 RC so throttle is available (egads, another 10 grams of servo and linkages) and top end will be down over the C/L combat versions. Once/if I get used to the aircraft maybe I'll swap out engines later. I do have dual rates and will make good use of them. Thanks for the throw recommendations, I am pretty new to deltas, esp. small ones, so had no idea where to start and I did not want to loop it into the back of my head or corkscrew it into the ground half a second after launch. I've hit myself once with an RC airplane and that was quite enough!
MJD
