thanks for your help bob27, wilkigmc and soarrich, i am using the muffler that came with the engine, the tank is directley behind the fire wall, the chunk line is fairly long, ill shorten it up and see if that helps, and as for increasing the muffler back pressure, what would be the best way to do that? steel wool? again thank you for all your help!!
Pat!
