RE: Flight incidence question
You set the incidences relative to the thrust line. Once you level the plane relative to the thrust line you set the wing incidence and then the stabs. You have to have a reference level line somewhere on the fuse to work from. You can set the stab relative to the wing or vice versa I guess, but you have to set the 1st one relative to the thrust line.
