RE: Sig Somethin' Extra Build
Thanks for the suggestion. The windex method is used primarily for Monocote. Windex doesn't activate the adhesive on ultracote. I did use it to position ultracote checkers on my last plane but the liquid didn't help when it heated and turned to steam causing more bubbles under the covering. I say don't use it with ultracote period. This is my preference though.
Just enough heat to activate the adhesive worked great for the ultracote covering without causing bubbles. Just position it carefully and hold in place when mounting.
somegeek
