RE: Flight incidence question
If you are wanting to check the incidence of the wing relative to the stab, level the stab and then check the incidence.
I would try to see what the incidence of the Twist is suposed to be and what the designer used as a reference for zero. That would be the best starting place.
What is it you are wanting to do? Are you wanting to change something?
