RCU Forums - View Single Post - T-Rex for AFPD
Old 06-02-2006 | 10:41 PM
wcc963's Avatar
wcc963
Default RE: T-Rex for AFPD
Ok, setting up your heli. first do you have a programable radio it would make it alot easier, but we'll do it through AFPD. First select what aircraft you want, and select edit aircraft. Select the main rotor, and then select the last little button on the bottom... the one for contrls. what i do it put the pitch inputs at there min and max to have ultimate control. Then Select the cyclic control and put it on 4.5. This is still senvitive enough to do mild aerobatics but dull enough to hover easily. If you have any other questions just ask and I'll do my best to help.
Chris
