ORIGINAL: RCIGN1
Electronic advance reaches full advance at 4000 rpm, mechanical is linear with throttle movement to 28 degrees advance at wide open throttle..
Hard to tell the difference between the two...
RCIGN1 - Well I think I asked the wrong question because you replied in Greek....[&o]
You have my engine there at your shop, I am debating the Mech advance conversion now that you have it, What will I gain from this conversion. Will I gain RPMS, torque, smoother running and starting. I am under the impression that you have smoother transistions with Electronic ignition, is this the case with mechanical conversion as well.
Pleae forgive my ignorance as I am only familier with the zenoah and magneto setup and can be hesitant on things at tiomes until I fully understand what is involved.
Jeff
