Mk dual elevator coupler on G-trick?
The expression of the "standard" may not be right. @Forgive me because it is poor at my English.
Two piano lines were glued at the tip of a long stick of balsa.
I think that it is the same as your probably imaging it.
It will probably be good Y-rod when sliding and so on is adjusted in the high precision before sticking a bottom board of fuselage.
kobayan
