RE: 3W carb replacement
Thanks Garrett
Yeah, ignition sounds like the probable cause, and you are right the 3w-100 seems to have better throttle response than my DA-100 (I might be dreaming, but it might be more powerful too).
Someone said that the DA ignition is a direct, bolt on replacement. I could try the ignition off of my DA and see if it solves my problem????
