RE: 3W carb replacement
The DA ignition and the 3W ignition that I have (several years old) are interchangeable. They use the same pick-up technology (coil, not hall-effect sensor). So you can swap the ignition module, but leave the pickup sensor in place. You may have to solder on a different connector between the sensor and the module, I can't remember for sure.
