RE: Ultrafly Ultimate
Ok,ended up with a JR radio XP 6102 with 241 servos (17 OZ torque)
Running the E fligth 480 outrunnner with Phoenix 35 amp and juiced by a Flight power EVO 20 2150 lipo.
maiden went well and immediately felt comfy with it.Took off from grass in 15 feet at 80% power.Pretty solid in the air.Flew like a .40 size plane.Previous reviews showed that 100mm CG is consevative,so I slid the pack in a little ways to get aft CG.Flew just to my liking.Can fly nose high and ultra slow.Hovers at half throttle and pulls out hard.Flew for 13 minutes and Triton charger was only able to put in 1300 mAh,and I was good to go again.another 12 minute flight without power loss.This time the battery was a bit to far aft and CG became pitch sensitive even with 50% expo.No bad behaviour though.I landed with some throttle to control descent and landed at a walking pace.Flies very well and can do so slowly.Harriers good.I need towork on some set up possibly,as precision was not its strong point today.Things were a bit sloppy and coupling was noticable.Will report back after some tweaking.
