RE: Predator II ??
Hi Guys, I Have A Predator Just Finish Putting It Together, Im Just Wondering The Wing Plate That You Get To Hold The Wing Down With, & Also To Hold The That Back Plate Where The Servos Are Mounted, I Have Used Another Way 0f Attaching The Plate For The Servos. So Could I Get Away With Not Using The Wing Mounted Plate. 0r Should I Still Use This Plate For The Wing So The Wing Mount Screws Dont Pull Through The Wing!!!
