Hi People:-)...
I have Aerofly pro also, And I just won in a raffle the G3 with the #1 add-on... I have been
trying G3.. For a bit now.... I may just be more use to AFP... But I think its better overall, plus
you can get tons of "free" D/L'ed models to fly... (The heck with $29.99 to get maybe a few models
that you really want) The graphics may be better... but there is AFPD
I don't really use the sim much... But when I can't fly for a while and or practice old/new move it
does help..... And I "REALLY LIKE" the repairs on the sim.... Low and Slow is a breeze now
Bliss..... IMHO...... I really believe standard BB servos of atleast 57oz is all that the Do needs to do
all that it can............ But the big boy's does not hurt... Well maybe a little in the pocket book...
Well, My "Do" has been doing great!!! No same setup on the ant[:@].... But the last few flights the
"Do" has been really singing... At first I just took it for the "Do" harmonics... But then a fellow
member asked, "is your prop balanced?" I said sure, with my finger balancer.... He tells me to buy
a good balancer, that finger balancer is "C__ap.. Anyway I recheck it, using my "C__ap" balancer...
Try it again... No change.... So at home I went through the "Do".... And for what ever reason my T.T.
spinner backplate was spinning on the hub.... Even with the prop nut and spinner adapter nut tight..
I mean tight(my problem in life)... So tight that the tapered end od the adapter cracked off between
the prop nut and shaft threads
... It took a bit to get the nut off, But all came off in good condition..
Will see in the AM.... with my now spinner-less "Do" And when I get back home... Maybe my new
balancer will be at the door....
Gary.............. Hey thanks guy!!!!!!!!......... The S 100 spins smoother than "Butta"..... Let's see...
Up on the crank connecting rod pin.... Down on the cam timing mark........ K... I can do that
