RE: Engine Help.
How do I check for a leak in the high speed needle? That will be my next cource of action. Done for tonight, but gonna bring it to the field tomorow if daves around and have him look at it now that I have found out how to actually replicate the problem every time on the ground. That was a new discovery today, but if no go after tomorow I'll start checking into problems in the engine itself. After it quits it fill fire right back up if I open the throttle a touch. I've been messing with the highspeed a bit, and it hasn't seeme'd to help. I'll lean it out till the pitch drops, go back to peak and then richen a bit. I tried it once right at peak. I may try resetting the low speed if I'm not gettin anywhere after next round. But I would think if it was off, I wouldn't be gettin good transitions, and having good pinch test results.
-John
