RE: Predator II ??
Hi Ya Budman27, Thanks For The Imformation 0n The Predator. I Will Glue The Plate 0nto The Wing,
Just Incase. If I Dont Use It, Its Just My Luck The The Wing Bolts Might Just Pull Through The Wing.
& I Will Loose The Whole Plane! Any Way My Predator Weighs In At Just 0ver 3 1/2 LBS. With A 46 0S AX & Used A 600 MAH Battery Pack! 40Z Bubble Tank. I Am Going To Test Fly It This Weekend, So Here's Hoping Its Faster Than My Viper With The Same Gear!
