RE: Showtime
I had someone else fly my plane and it does it for them too. I found out if you pull hard vertical it will do it. This is on low rates which is about 55% of the full travel. I also put higher torque servos in the tail so thats not the problem. One question though, how do you measure the incidence at the root because the robart meter isn't big enough? I just measured it as close as it would let me.
