RE: GP Super Stearman
OK, I am new to gas and need a litttle help now. I am at the point of hooking up the kill switch and the fuel lines. First off, the on/off switch has two leads, one with a plug type end, does that get pluged into the black lead hanging off the coil on the G26? The other end has a round washer type end, does that just get grounded to the engine? Should I put that end through one of the four mounting screws or what? Also should I just mount the on/off switch on the side of the cowl then? The other thing is the fuel line hookup, I would like to use the fuel dots, so do I run one line form the fuel dot to the tank, the other line from the klunk in the tank the the carb, and a third line from the vent to the bottom the the plane?
