RCU Forums - View Single Post - Beginner advice needed
Old 06-05-2006 | 12:20 PM
DepronJet
Default RE: Beginner advice needed
Tom
not knowing your set up i can only advise on why you type
there is a set up called expo !
it means if you move the stick a little using expo not a lot happens.. move it a little more and nothing much more happens.. but move it a lot and then you get full movement..
top pilots use it for good fine aerobatic moves..
it can help if your heavy on the fingers
amybe this will help you.. but you need a computer TX to set it up !
More $$$$$ [&o]
RAy
