RCU Forums - View Single Post - Futaba T2PH Problem
Old 06-05-2006 | 01:54 PM
Krysta
Default RE: Futaba T2PH Problem
Hi Cole,
It could be something as simple as dirty contacts in your battery tray to something not connected on the board. I would check the battery contacts, and battery lead first, this would be the easiest to see and fix.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta Hunt
Lead Futaba Customer Service and Programming Technician
Futaba Service Center USA
ORIGINAL: Cole_lol
Hello,
I have a Futaba T2PH Radio for RC Cars and when you replace the batterys on it the low level LED stays lit up... I have tryed diffrent sets of batterys and even checked the voltage of all the batterys to make sure there is no issue... What could possibly be the issue and is there any way that I could fix it... I am perty savy when it come to electronics so componets are not an issue... Any help would be wonderful...
Cole
