pull pull 1/5 cub cables
I am having a realy hard time with pull,pull rudder cables on my sig cub. First full build for me.It took me a couple hours to even fish the cables through the fuse! Wish i would have installed them before covering. I have them atatched at the servo. but when i look through the cabin they apear crossed. If i pull on the right it is atached to the right side though. Same on the left side. Witch must mean they are wraped around each other not just crossed? Crossed i have seen in other threads as okay. Wraped around can't be good though. will probably bind. Also starting to wonder about stringers and formers rubbing? Just had a thought "maybe ill remove servo arm and try flipping it around to untangle. Im getting anxious to finish the plane. Elevator & throtle servo,cowling,reciever, balance,throws,think thats all thats left. Any advice would be great ,thanks.
