RE: pull pull 1/5 cub cables
Had this problem a few times on ARTF's my solution is to feed in yellow nylon push rod material from the tail forward, I secure the push rods only at the tail with epoxy, the front end is left free to float so that the angular displacement of the servo arm causes no problems then its a simple matter to install the cables through the push rods, safe in the knowledge that theyll run nice and free without damaging servo wire etc.
