RCU Forums - View Single Post - ARC Jupiter
Thread: ARC Jupiter
Old 06-06-2006 | 09:19 AM
tony221264
Default RE: ARC Jupiter
Hi Sidav
from memory i think the engine is mounted horizontaly, make sure the mounting lugs on the engine with the screw holes in them are in line with the sides of the engine mount, if you have the engine skewed in the mounting it will give you up or down thrust. hope that sounds clear.
regards Tony
