RE: Brake valve programming
First thing, erase all previous programs by pressing 5 times. Shut off and turn back on...
Now..........Hook up a standard servo to your brake channel. Watch the servo travel and adjust for max travel. Set the travel and then hook up the valve. If you are using a 10x...go to servo monitor (function 75) and see the channel throw limits. Chances are you need to program in more travel .....or less travel.
If you are still having problems...call me.
260-724-8936
