RCU Forums - View Single Post - Which direction to mount the engine?
Old 06-06-2006 | 01:39 PM
Missileman's Avatar
Missileman
Default RE: Which direction to mount the engine?
I have, in the past, extended a needle valve with a piece of wooden dowel rod and some heat shrink tubing. worked great.
Holes in firewall? engine mounting holes (with blind nuts) a hole for your throttle connection and holes for your fuel lines, 1 more hole if you use the remote glow adapter I mentioned before (IF you want to mount it in your fuselage)
