RCU Forums - View Single Post - Solutions for RF Issues on Long Leads
Old 12-24-2002 | 10:16 AM
William Robison
Default Solutions for RF Issues on Long Leads
WoketWabbit:
Another method that has worked well for me is the use of RG-179 coax. Leave the power and ground wires alone, run the signal only through the '179. As Mike said, in post #2, tie the shield to ground (negative batt lead) only at the rx end.
Advantage is it's lighter than the 3-cond shielded, and you eliminate the possibility of cross talk through the positive lead.
Crosstalk and RFI cause glitches,
. and they're nasty little sons-a-b.........
Bill.
