ORIGINAL: NitroMayhem
I love mine too. Wish I had got the one with the Spektrum radio but I found a DX3 on ebay. I have only broke an A-Arm or two and bent the rear shock tower but that was cause I flipped it on pavement with the body off. Adapting a wing is easy. I useD the Mugen kit with and HPI wing. That will help protect the truck, fly in the air, downforce and stability. It's faster than my Revo I swear. And no other trucks pass me on the straights. The motor is real good (based on the Mach 26).
http://www.timberlineraceway.com/pho...g&limit=recent
Here's the upgrades for the Mayhem ST. (Horizon Hobby dot com)
SWK9158 - TORQUE ROD STIFFENERS (HIGHLY RECOMMENDED SO THE CHASSIS DOESN'T TWIST UP)
SWK9291 - ALUM FR UPPER ARMS
SWK9290 - ALUM FR LOWER ARMS
SWK9284 - ALUM RR ARMS
SWK9154 - ALUM RR HUBS
SWK9006 - TI NITRIDE SHOCK SHAFTS (ANOTHER EXCELLENT UPGRADE)
SWK9010 - RUBBER SHOCK BOOTS
SWK9098 - ALUM DIFF HOUSINGS, FR & RR (FO SHO GET THESE)
SWK9097 - ALUM CENTER DIFF HOUSING (THIS TOO)
SWK3186 - WING MOUNT ASSEMBLY
SWK3188 - WHITE WING
SWK9200 - POLISHED 053 INLINE EXHUAST
SWK9163 - 5MM RR SHOCK TOWER (NOT 100% THIS FITS THE ST, SHOULD BE EXACTLY THE SAME AS FOR THE 1/8 BUGGY. AS ARE THE RR SHOCKS, RR ARMS, ETC.)
I run mine with 40 series pro wheels with the CrimeFighter MT's (BowTies are good also). The stock wheels are offset but if you get the non offset wheels it will turn and track better.
