RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 06-06-2006 | 10:18 PM
  #694
captinjohn
Default RE: gas fuel with glo plug no ignition
It seems like a tapered reamer with the same taper would be the way to go. Just make a threaded coupler and then cut the taper in it, to fit on crankshaft. My question....is there such a tapered reamer on the market? Are you sure that the flywheel you have now cut down so the center portion is still there with taper, will not work good. All you need is 1/2 of threads and some loctite. Thanks Capt,n
