If the spark plugs are WSR6 or NGK BPMR6 they can be replaced by the NGK CM6 10 mm spark plugs as used by 3W and DA and some others...You will need some adapters from C&H to reduce the 14mm thread to 10mm..The CM6 plugs are not resistor..C&H makes a shielded cap. I have resistor caps made by NGK, but not shielded...The resistor caps ar $10.00 each, not sure of the price from C&H for the shielded caps...
www.ch-ignitions.com
The CM6 NGK plugs can be found at some Honda dealers, about $3.00....
