RCU Forums - View Single Post - gas fuel with glo plug no ignition
Thread
06-07-2006 | 11:59 AM
697
av8tor1977
My Feedback: (
6
May 2003
7,245
Tucson, AZ
RE: gas fuel with glo plug no ignition
cal.45acp, I think I have your answer. At least if the taper on your crank is the same as a Ryobi. If so, what you want is a prop adapter from CH Ignitions for a short shaft Ryobi. It has a unique tubular through stud that goes through the prop adapter. The aluminum prop adapter itself floats on this stud, and is held against the the crankshaft taper by the propellor and propellor nut. It's a slick system for a very short shaft engine.
See pics.
I would like to add however, that I have used the same method as Capn John on many engines and it works fine. Just use a hole saw to cut out the center of the magneto, chuck it up and dress it round, and use it behind a prop adaptor designed for engines with magnetos.
Good luck,
AV8TOR
Reply
Like
av8tor1977
View Public Profile
Send a private message to av8tor1977
Visit av8tor1977's homepage!
Find More Posts by av8tor1977
View iTrader Profile
