ORIGINAL: srm99
plenty for low rates
Depending on where you put your CG, you may end up dialing down the elevator...if you pull full elevator on low rates and it corkscrews instead of looping you have too much elevator!
I show people the throws for low rate and most people that have never set up a plane with airfoiled tail surfaces can't believe how little the control surfaces move for how much maneuverability I have in the air.
Good luck flying and enjoy!
