RCU Forums - View Single Post - Pull-Pull and flutter
Old 12-24-2002 | 11:15 AM
planelazy
Default Pull Pull
HI philip. The cables should be snug so there is no slack at neutral. Also you should use a double ball bearing servo as to handle the tension on the servo shaft. Tim.
