Edge 540
I went to the link to EBAY, and this is the first kit with sheeted foam wings.
Builds OK. I liked the second one better as it had removeable stabs and the hatch was open all the way to the firewall. Only issue I had with it was the tank location.
They have you build it to mount under the wing tube and a 16oz tank is about all that will fit there. Even then it was a bear to get to for service. May be too low a location for the Moki without a pump. You will likely have to put the tank in front of the wing tube, not on the CG in order to get the larger tank for the glow motor.
Check the lower stringers and replace if they look weak. I never had one fail in flight, but easy to damage during handling.
