RCU Forums - View Single Post - Float plane not flying
Old 06-09-2006 | 02:47 PM
Flyfalcons's Avatar
Flyfalcons
Default RE: Float plane not flying
Your floats should be set up so the step on the bottom of the float is 1/2"-1" behind the CG. The top of the floats should be parallel to the centerline of the fuse and wing saddle; this setup should prevent the plane from lifting off until it has reached an adequate speed.
