RCU Forums - View Single Post - Dave Brown Fiberglass Pushrods
Old 06-09-2006 | 08:00 PM
captnem
Default Dave Brown Fiberglass Pushrods
I am installing a fiberglass pushrod in my airplane. I have it all setup, except for the connection to the servo. I am not sure how to securely connect it. The instructions say to measure and inch and then bend the wire 90 degrees and drill out a hole in the fiberglass rod...and put the plug and the wire in and glue it. Is this the best way??? That 90 degree bend will have to be very small (the diameter of the tube). Do you guys have any suggestions for me? I really want to keep this setup, just want it to be right. Thanks!
