RE: Eletronic engine syncronizer - no joke
Guys,
The production unit will have 6 LEDs. The two additional LEDs indicate when the onboard glow plug driver is turned on. A 5th mode is added so that you can use auxillary channel to control remote glow on/off. The other modes are still there. So my plan to turn on/off remote glow if AUX channel is not used for remote glow is the following:
If Engine not running full throttle for 3 seconds then idle turns on remote glow for 30 seconds. What do you guys think...
BTW the remote glow circuit could also be used for ignitition battery on GAS but I need to test this further before committing to this.
