RCU Forums - View Single Post - Power panel questions
Old 06-10-2006 | 10:54 AM
Rodney
Default RE: Power panel questions
Power panels typically put out a pulse of 12 volts for 1 millisecond then nothing for 9 to 10 milliseconds then repeats. This averages out to about 1.2 volts. If you use an oscilloscope you can see this pulse train. You must have a load on the unit to have it work. The pulse is usually generated by an LM555 set up as a pulse generator with its output driving either a power transistor or Power FET.
