RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 06-10-2006 | 12:01 PM
  #3504
zooland1's Avatar
zooland1
Default RE: E-FLIGHT BLADE CP
I use velcro on the battery and then pop a rubber band around it to hold it in place. I'm using lipos so my battery is out front. If your battery is back farther you can loosen the battery tray and slip a band around it under the main gear. If you're having trouble getting the velcro to stick, wipe the battery with alcohol to remove any residue.
