Since its a 4wd we are going to run on the Unlimited MT class, i don't how we are going to do, running against those giant 1/8 scale should be fun
. Going to stay away of those heavy weight or we are going to get crushed.[sm=bananahead.gif]
CB problem
Did you try to put a shim before you install your CB on the pilot shaft, in order=(pilot shaft,washer,bearing,CB,bearing,washer,screw)
(are you still running the RTR CB with the needle bearing)
