ORIGINAL: danny31292
Well this is what i thought. I am obviously using more than 33mah. I was always tought to only do 4 flights. I have one question though. Do voltmeters that you mount on the side of the plane measure the battery under a load?
Dan
If you are referring to something like Voltwatch the answer is yes. It plugs into an empty slot in your receiver and is only on when power to your receiver is on.
