RE: Official HPI MT2 Thread
Yeah I have the RTR bearing. Has that been my prob the whole time? I didn't understand why you had bearing twice my order (pilot shaft, washer, bearing, cb washer, screw). I just finally got my truck all together from yesterday when my flywheel came off and my clucthbell got jammed against spur gear. Well I'm starting a tally, everyone said all you need is the .18 cvrx and motor mounts, I guess people forget you need new washers and maybe new bearings, I just wished I knew so I could have put it together right the first time.
I just searched Tower hobbies for 15min, I can't find any other bearing other than a needle bearing set with 3 washers (not sure what third one is for. Could you please post a link to the bearing I need if in fact that is my prob. Well heres a pic I just took of my truck and my pup car was all set except for reciever and gas tank, since nothing has happened to it so far running like its running I'm going to keep on bashing until my order arrives (should be here by next Monday).
