RCU Forums - View Single Post - Microsoft CFS 3 - need HELP!
Old 12-25-2002 | 06:58 PM
Pepe J
Default Microsoft CFS 3 - need HELP!
Thanks for the tips and reply's. I will definitely present my problem at the web site suggested by you GM8600.
Thanks Dave, I think you're one the right track? One of the trouble shoot tips is to adjust the Virtual Memory to a Min/Max of 1024mb. I have tried a number of different settings. Improvement? Yes, but not much. I think you maybe correct about Win. 98 thou. I'm going to try the program on my Daughter's system. She has twice the system using Win. XP, but has the same Video card. This should help eliminate a problem possibly.
I noticed the frame rate is only 15-30 fps? I have seen it as high as 65fps. Real flight G2 runs around 85fps. There was a trouble shoot about a override/ bypass of the Video card and Motherboard, but I really don't want to venture there at this time.
I was hoping to find someone with the exact same problem/system and knew of a cure, but I'm still open for suggestions. Thank's again and both you Fella's enjoy the X-mas season.
Pat.
