RE: RCV Engines
Well finaly got some time in the air after a ton of CG changes. This motor does not produce the rpm that it states it should. I am using Omega 15% caster blend w/ APC 14x7 and only getting 7900-8000 rpm's. This motor would barely fly my spit at just over 11lbs. I will continue to run it as it has just a gallon through it now and needs more time on the motor. Just wanted to note this for future references if needed.
Shane
