RCU Forums - View Single Post - BLIP CAMERA PROBLEM
Old 06-13-2006 | 11:48 AM
TOMAPOWA
Default RE: BLIP CAMERA PROBLEM
Out of curiosity, what type of power source is powering up your camera? (i.e. are you using a BEC off of your motor controller or are you using a battery pack). Aipteks can be very funny in that they can experience this color distortion when powered from a source other than two AA cells. I mod my cameras so that they connect directly to the USB connector (no worries about the camera auto turning off either when powered this way) and this method of powering filters and regulates the input voltage. Does any one know if Blip uses a voltage regulator in their design? (i hope so). I think they are simply powering up the camera using the original battery terminal connections.
