double aileron servos
I've got a question for those who have used two aileron servos instead of one. The kit includes the additional hardware and has holes in all of the ribs etc to run the servo wire... but what method did you use to run the servo wire out of the wing? The instructions call to "sheet the top of the wing just like you did the bottom". Doesn't make for running the wire right out. My current thought is to build the center of the wing just as it would be for a single servo, except not cut out the W1 ribs as called for in the center. Then not sheet that area to let the wire out. Any thoughts?
