TUBES
Does it not call for the addition of paper tubes to be rolled up to be inserted into the wing holes that are punched/ lasered out to accommodate the servo wires? I used that method and then I hard wire my servos into the wing. Meaning I don't use servo extensions. I cut off the wire about 1" from my servo then solder wire to it and use shrink tube on the solder joints then run the wires out the tubes and get the proper length, and depending on weather you want to use flaperons is how I end the wires. Meaning if you want to use flaperons you just solder the connections back onto the ends of BOTH servos then connect them to the extensions you have coming out of your receiver, from ports 1 & 6. If not you just solder the connectors back and the when you insert your wings you just hook them to a Y connector that is out of the #1 port in your receiver. If I am not using a plane with 2 wings such as the SE. I will solder the wires together and do away with the Y connector all together. The less wire length you have better.
The DiBo :spinnyeye
