RE: Bad Pushing Problem(w/ hyper PCR)
Ive found a good set-up for the Hyper 7 PCr to be 5 front, 5 mid, and 1 rear. Also A good base set-up is too have the car leaning slightly backwards. I have 40 WT in mine, and The stock sway bar in the rear, and i took a replacement swaybar for the rear (same as sotck one), cut a little bit off of the ends, and am using that in the front. Tthe sway bars they makes for the front really dont fit well at all, at least not the 2.4mm. I happen to ahve 7 worth preload spacers in the front and 6 worth of preload spacers in the rear, and mine seems to handle very well.
